I can't program EEprom AMD 29F010
Postby Guest » 14 Nov 2011 16:28
I never had problems programming with S4, but it's a couple of days I can't program any eeprom, and I don't understand why.
It seems like they are empty.
I program AMD 29F010 eeprom and there are 2 files *.hex, the first wit the system file and the second with application load charts.
But if I load a particular file *.hex, where I have both the system and application, it works as always.
It seems that S4 doesn' load the second file now.
Anyone can help me? Thanks!
Fabio
Re: I can't program EEprom AMD 29F010
Postby Dataman (Neil Parker) » 14 Nov 2011 16:28
Hello Fabio,
I dont fully understand what you are trying to do. You mention two .hex files which I assume you want to load into the S4 and program to a 29F010 device. What are the address ranges of the data in the two files and what are the steps that you are using to load them into the S4? If you could email both files to [email protected] with instructions on where you want the files in the device then I can have a look at them for you.
Which library version do you currently have loaded in your S4?
I will wait to hear from you with the two files and will post the solution back here once resolved.
Postby Guest » 14 Nov 2011 16:29
I've just fixed it, bad parameters for the "fill" function after reset. :D
Fabio
Postby Dataman (Neil Parker) » 14 Nov 2011 16:29
Hello Fabio,
Ok, glad to hear that you managed to resolve the problem.
Return to “Dataman S4”
