Added adapter: BGA-Top-366 ZIF-CS
Added adapter: DIL48/QFN48 ZIF ARM-1
Added adapter: DIL48/QFP48-1.02 ZIF LPC-3
New software - Version 3.42
Postby Dataman (Daniel Smith) » 12 Jul 2018 13:35
