Revert USB driver to 3.24
Added adapter: BGA-Bottom-442
Added adapter: BGA-Bottom-476
Added adapter: BGA-Top-426 ZIF-CS
Added adapter: DIL48/QFP100-1.02 ZIF LPC-10
BGA-Bottom-231, improving of pgm parameters assignment
BGA-Bottom-219, improving of Automatic YES!
New software - Version 3.43
Postby Dataman (Daniel Smith) » 10 Sep 2018 11:04
