Revert USB driver to 3.24
Added module: AP1 BGA169-3.01 eMMC-1
Added module: AP1 BGA64-7.1 ZIF STM32-3
Added module: AP1 QFN32-1.02 RTL-1
Added module: AP1 QFN48-1.02 CC-3
Added module: AP1 QFP100-1.02 ZIF R5F-5
Added module: AP1 QFP176-1.02 ZIF NEC-3
Added module: AP1 QFP48-1.02 ZIF NUC-2
GigaDevice GD25D10B [USON8], insertion test modified
Micron MT28EW01GABA1HPC0 [BGA64], power-up sequence modified
Micron/Numonyx/STMicroelectronics M29W640GTxxZA [TFBGA48], added support
Nuvoton M052Lxx, M054Lxx, M058Lxx, M0516Lxx [LQFP48], added support
STMicroelectronics STM32L07x and STM32L08x in LQFP64 package, module assignment fixed
New software - Version 3.43
Postby Dataman (Daniel Smith) » 10 Sep 2018 11:07
