Added adapter: DIL48/PLCC68 ZIF PLD-4
Added adapter: DIL48/QFN33 ZIF-CS module BT121-1
Added adapter: DIL48/QFN40-1.02 ZIF TPS40-1
Added adapter: DIL48/TSSOP14 ZIF STM32
GigaDevice Semic. GD25Q127C [SOP16] (QuadSPI), added support
New software - Version 3.44
Postby Dataman (Daniel Smith) » 12 Oct 2018 14:23
