New software - Version 3.49
Postby Dataman (Daniel Smith) » 16 Apr 2019 16:10
In PG4UWMC Gang mode is modified handling of multiply buttons YES! pressed at the same time, to preserve currently running operations on Sites to display their operation results correctly
Added adapter: DIL48/LGA62 ZIF module S76S
Added adapter: DIL48/QFN28-3.02 ZIF PIC-1
Added adapter: DIL48/QFP48-1.02 ZIF R5F-5
