New software - Version 2.69
Postby Dataman (Daniel Smith) » 15 Nov 2011 10:29
Atmel AT45DB161D, programming bug fixed
Atmel Serial DataFlash, fixed Unexpected error 1 [IEC:2, D:3C]
