New software - Version 3.50
Postby Dataman (Daniel Smith) » 30 May 2019 14:07
Added adapter: DIL48/QFP100-1.02 ZIF Kinetis-7
Added adapter: DIL48/QFP32-1.04 ZIF CY-1
