New software - Version 3.50
Postby Dataman (Daniel Smith) » 30 May 2019 14:10
Added adapter: DIL48/QFP100-1.02 ZIF Kinetis-7
Added adapter: DIL48/QFP32-1.04 ZIF CY-1
XTX XT25F32B [DFN8 2x3] (QuadSPI), XT25F32B [DFN8 2x3], added support
