New software - Version 3.51
Postby Dataman (Daniel Smith) » 05 Jul 2019 10:08
Added adapter: DIL48/SOIC8-150 ZIF STM8-2
Added adapter: DIL48/QFN48-2.02 ZIF CHIL-7
Added adapter: DIL48/QFN64-1.02 ZIF ADM-1
Added adapter: DIL48/QFN64 ZIF MSP430-3
Added adapter: DIL40/TQFP64-2 ZIF PIC-1A
Added adapter: DIL48/QFP100-1 ZIF-CS R5F-7
Added adapter: DIL48/WLCSP143-1 ZIF-CS STM32-1
Added adapter: DIL48/QFP176-1.01 ZIF-CS S78-1
DIL48/TQFP64 ZIF AVR32-2, default automatic yes parameters modified
DIL48/TQFP100 ZIF AVR32-2, default automatic yes parameters modified
DIL48/LQFP144 ZIF AVR32-3, default automatic yes parameters modified
DIL48/BGA1152-1 ZIF PLD-1, power-up sequence improved
