New software - Version 3.51
Postby Dataman (Daniel Smith) » 05 Jul 2019 10:10
Added module: AP1 QFN24-1.02 ZIF CY-2
Added module: AP1 QFN32-1.02 ZIF STM32-2
Added module: AP1 QFP32-1.04 ZIF MC56F-1
Added module: AP1 QFP44-1.04 ZIF CY-1
Added module: AP1 QFP48-1.02 ZIF R5F-6
Added module: AP1 QFP48-1.02 ZIF NUC-5
Added module: AP1 QFP64-1.02 ZIF CY-1
Added module: AP1 QFP64 ZIF FM3-2
AP1 MLF32-1 ZIF-2 bug fixed
