New software - Version 3.52
Postby Dataman (Daniel Smith) » 24 Sep 2019 15:49
Added adapter: BGA-Bottom-484
Added adapter: DIL48/BGA50-1 ZIF nRF-4
Added adapter: DIL48/LQFP48-1 ZIF HD64-2
Added adapter: DIL48/QFN24-1.02 ZIF NHS-1
Added adapter: DIL48/QFN32 ZIF PLD-3
Added adapter: DIL48/QFN40-2.02 ZIF MP-1
Added adapter: DIL48/QFN48 ZIF STSPIN32F0-1
Added adapter: DIL48/QFN48-1.02 ZIF NUC-2
Added adapter: DIL48/QFN48-1.02 ZIF WNF-1
Added adapter: DIL48/QFN64-1.02 ZIF R5F-1
Added adapter: DIL48/QFP144-1.02 ZIF SH-2
Added adapter: DIL48/QFP32-1.04 ZIF MagniV-2
Added adapter: DIL48/QFP48 ZIF STM32-3
Added adapter: DIL48/QFP52-1.03 ZIF LAPIS-1
Added adapter: DIL48/QFP64-1.02 ZIF R5F-15
Added adapter: DIL48/QFP64-1.02 ZIF TER-3
Added adapter: DIL48/TSSOP30-170 ZIF BQ78-1
Added adapter: DIL48/WLCSP81-1 ZIF-CS STM32-1
Added adapter: DIL48/WLCSP36-3 ZIF STM32-1
Added adapter: DIL48/QFN20-5 ZIF STM32
BGA-Bottom-249 + BGA-Top-263 ZIF-CS, insertion test modified (NAND flash devices in BGA100 package)
DIL48/QFP64 ZIF MB95-7, update of SW interface
Discontinued adapter DIL48/QFP48 ZIF STM32-2, replaced by DIL48/QFP48 ZIF STM32-3
Micron MT25QU01GBBB8E [SO16W] (Quad I/O), added support
STMicroelectronics STM32F446MxY [WLCSP81], adapter changed to DIL48/WLCSP81-1 ZIF-CS STM32-1
