New software - Version 3.03
Postby Dataman (Daniel Smith) » 28 Jan 2014 11:49
Version 3.03 features the following amendments:
Allowed resize of dialogs Special options, Device operation options, Program?, Erase?, increased constraints for their maximal dimensions to allow fit whole screen
Improved error detecting in programming adapters checking
Fixed communication bug for multiprogrammers
Fixed no signal output on OK and ERROR pins of ISP connector
Fixed remote control conflicts that could cause errors, when quickly sending remote commands to PG4UW
Repair "'\VID' is not a valid integer value" error message
Modified PG4UWMC USB events
Fixed in PG4UWMC - report log file 'reportmc.rep' correctly added to Problem report, even if setting "Add date information to Log file name" is selected
Fixed in PG4UWMC for JAM/SVF/VME devices - suppressed undesirable displaying of buffer checksums
Added support of Hitachi HD6473837H [QFP100] by the new adapter DIL48/QFP100 ZIF-CS HS3836ESH01H (replacement of 3rd party adapter)
Atmel ATtiny13 (ISP-SPI)(OSCCAL), modified comment for check box for writing of the calibration value
Atmel AT17F32A, improving of stability of pgm. actions
Atmel AT45DBxxxD family, improved Sector Erase
Atmel AVRxmega A3/A3U/A3B/D3/C3 family, Insertion test modified for adapter DIL48/QFN64 ZIF-CS XMEGA-1
Atmel AVRxmega in ZIF mode, modified insertion tests for all adapters
Azoteq IQS227AS, programming procedure improved
Freescale Semic. S12Pxx family, programming security state improved
GreenPeak, logging MAC address of programmed device
Lattice ispPAC-POWR605 [QFNS24], insertion test improved
Microchip dsPIC33EPxxxMU8xx/GP8xx/MC8xx, PIC24EPxxxGU8xx/GP8xx, programming algorithm improved
NXP LPC1112/102, new device ID code added
TI (TMS) TMS320F28335 [BGA176], power-up modified
Xicor X28HC256, modified power-down sequence
Atmel ATtiny25/45/85 [MLF20], fuse bits programming error bug fixed
Atmel ATtiny4/5/9/10/20/40 in ZIF, wrong skipping of the blank blocks during programming bug fixed
Cypress CY7C63803 [QFN24], insertion test bug fixed
Energy Micro devices with flash size lower than 32kB, main flash page protection bug fixed
Fujitsu MB96F386xxx, programming bug fixed
Macronix MX26L12811, erase procedure bug fixed
Maxim DS28E15 [TSOC6], Device synchronization error bug fixed
Microchip dsPIC30F6014, programming bug fixed
NAND flash devices, range check error during blank test fixed
NEC uPD70F352x, operation on Data flash memory fixed
Renesas R5F1xx, operation on Data flash memory fixed
Samsung KLMAG2GE4A-A001, communication error bug fixed
STMicroelectronics STM32F050Gx, adapter name fixed (DIL48/QFN28 ZIF-CS STM32)
TI (TMS) TM4C123GE6 [LQFP100], insertion test bug fixed
Xilinx XCF04S [TSSOP20], blank check test bug fixed
