New software - Version 3.56
Postby Dataman (Daniel Smith) » 04 Feb 2020 12:47
Version 3.56 features the following amendments:
Fixed "Access violation" error that could appear for PIC16F1xxx devices when serialization is used
Fixed non working command line parameter /prj:... for PG4UW application
Actel/Microsemi A2F200M3F devices, power-up sequence modified
Actel/Microsemi A2F500M3G [FBGA484](STP), improving of overcurrent protection system
Added adapter: BGA-Top-402 ZIF
Added adapter: DIL48/PQFN24-2 ZIF CHIL-1
Added adapter: DIL48/QFN48-1.02 ZIF RTL-1
Added adapter: DIL48/QFN56-1.02 ZIF MAX-2
Added adapter: DIL48/QFN72-1.02 ZIF PLD-1
Added adapter: DIL48/WLCSP94-1 ZIF nRF-4
Added adapter: DIL8W/SOIC8 ZIF 200mil SFlash-1b
Adesto Techn. AT25QL128A [SOIC8-200] (Quad I/O), reading of OTP improved
Atmel AT28Cxxx, enable split function
Atmel/Microchip ATmega328PB [MLF32](OSCCAL@5V), Timing in power-on sequence modified, stability improved
Atmel/Microchip ATSAM3X8CA [LQFP100], initialization procedure improved
Atmel/Microchip ATtiny20 [WLCSP12], Programming module modified
Atmel/Microchip AVR8 family with UPDI interface in ZIF and ISP, Power-on, Erase and Programming enable sequence modified
ConvenientPower EC8010, programming/erasing EEPROM algorithm modified
DIL48/SOIC8-150 ZIF AVR-1, adapter renamed to DIL8W/SOIC8-150 ZIF AVR-1
DIL8W/SOIC8-150 ZIF AVR-1, software modified for the needs of new connection diagram
ESMT F50L2G41LB [WSON8], dual-chip support for OTP added (includes buffer size change)
Linear Technology LTC3887 [QFN40], power-up modified
Macronix MX25L6473F [SOP8-200] (Quad I/O), Verify of Status and Configuration Register improved
Macronix MX77L12850F [WSON8 6x5] (Quad I/O), MX25U3273F [SOP8-200] (Quad I/O), reading of OTP improved
Microchip PIC32MX695F512L 2wire JTAG mode, communication speed improved
Micron MT25QL128ABA1E [DFN8 8x6] (Quad I/O), MT25QL256ABA1E [DFN8 8x6] (Quad I/O), added support
Micron MT25QL256ABA1E [DFN8 8x6] (Quad I/O), MT25QL256ABA1E [DFN8 6x5] (Quad I/O),Package details correction
Mitsubishi/Renesas M38039/M38049 devices, programming modified
NAND flash devices, modified processing of OTP and various kinds of permanent block lock features, incl. <Alt+S> menu look change
TI (TMS) MSP430FR2033, programming procedure improved
TI (TMS) UCD9xxxx (P+D), verification procedure improved
Toshiba TMPM3HPFDFG (ISP-JTAG), setting of JTAG frequency feature added
Winbond W25M02GVZE [WSON8], dual-chip support for OTP added (includes buffer size change)
Xilinx CoolRunner-II/A, adding of Done bit verification after device programming
Xilinx XC1765E, adding of initialization in the main buffer according to Alt+S record
ABOV Semiconductor MC96F8208S [SOP16], insertion test bug fixed
Adesto Techn. AT25SL128A [SOIC8-200] (Quad I/O), AT25QL128A [SOIC8-200] (Quad I/O), programming of Status Register bug fixed
Atmel/Microchip ATmega328PB [MLF32](OSCCAL@5V), Power-on bug fixed
Linear Technology LTCxxxx, programming bug fixed
Micron MT29F128G08AMAAAC5 [VLGA52], pins assignment fixed (was 2x CE# only)
NAND flash devices, Linux MTD compatible mode - BBT write and verify fixed
Rohm BR93G46-3 (x16), BR93G46-3A, BR93G46-3B, programming bug fixed
Spansion/Cypress S6E1C1xD0AGV2 [LQFP64], S6E1C3xD0AGV2 [LQFP64], insertion test bug fixed
Xicor X5043/5, Status Register bug fixed
