New software - Version 3.60
Postby Dataman (Daniel Smith) » 30 Jun 2020 14:38
USB driver stability improved
Added module: AP1 QFN40-1.02 ZIF CY-4
Added module: AP1 QFN44-1.02 ZIF Z8F-1
Added module: AP1 QFN48-2.02 ZIF nRF-4
Added module: AP1 QFP80-1.03 ZIF MN103-2 (RD)
Micron MT25QU02GCBB8E12 [TBGA24] (Quad I/O), added support
Micronas HAL805 [TO-92UT], added support
Module AP1 SOIC20 ZIF 300mil AVR-1 renamed to AP1 SOIC20 ZIF 300mil AVR-2
Module AP1 SOIC20 ZIF 300mil AVR-2, interface modified
AP1 BGA672-1 ZIF NEC-1, initialization bug fixed
AP1 TSOP48 ZIF 18.4mm NAND-3, pins translation fixed (bad assignment for R/B2#)
