Posting a message about this as i've been struggling with this issue for years and only solution seems to be to use a different type of rom. Error is always the same. Must have tried hundreds of different M2732A roms so that cant be it.
Programming device: STMicroelectronics M2732A.
L0188: Buffer checksum in range of "Program Memory" [0h..FFFh]: 0007D38Eh - Byte sum (x8), Straight
L0189: Device insertion test ...
L0190: Device blank checking ...
L0191: Programming device ...
L0192: Communication error! (V:0/P:00/HW:00/EC:08/)
L0193: Elapsed time: 0:00:24.5
I have the full log error download attached to.
To be honest it doing my nut in as i need to program lots of roms daily and this is slowing things down massively.
Jim
Can't program certain 2732A roms
mypinballs
- Attachments
- PG4UW_LOG_windows_content_578-03481.zip
- (232.42 KiB) Downloaded 2191 times
Re: Can't program certain 2732A roms
Hello Jim,
Can you run the Selftest... from the Programmer menu using the diagnostic pod included with the programmer when purchased and let me know the result.
Looking at our software the algorithm for the ST 2731A was modified in v3.42 so if you can get the latest version running you may find the situation will improve.
Please let me know how you get on.
mypinballs
i was hoping with the software upgrade that it may solve it hence the other qu. Ran the diagnostic with pod self test. Results below
L0391: Communication test ............ OK 0:00:00.3
L0392: RAM test ...................... OK 0:00:01.5
L0393: EEPROM test ................... OK 0:00:00.9
L0394: Supplies and DAC test ......... OK 0:00:03.6
L0395: Pindriver (TTL) test .......... OK 0:00:05.6
L0396: Pindriver (GND/Analog) test ... OK 0:00:05.9
L0397:
L0398:
L0399: Selftest with Diagnostic pod successful.
L0397:
L0398:
Hello Jim,
The Selftest... result reveals that the programmers hardware is OK. Was this run on the latest software version v3.60? If it was, then please try programming the chip again and generating a new problem report and send it to [email protected] for analysis.
mypinballs
Thanks for the reply, but i'm still stuck on v3.34 at the mo. See other thread
Sorry!
mypinballs
Ok so i got past the software update issue and am running Version 3.60z09/09.2020 ok now but the issue with these damn 2732A roms is still there.
attached the new system log file
- Attachments
- (236.78 KiB) Downloaded 2217 times
