Fixed dimensions of some warning and error messages displayed from PG4UWMC, to correctly handle dimensions of message text
In PG4UWMC fixed Serialization From-file for large files (over 1MB of size)
Added module: AP1 QFN11-1 ZIF
Added module: AP1 QFN24-1.02 ZIF AUO-1
Added module: AP1 QFN28-1 ZIF
Added module: AP1 QFN40-2.02 ZIF TPS53-4
Added module: AP1 QFN48-1.02 ZIF EZR-1
Added module: AP1 QFN48-1.02 ZIF TLSR-1
Added module: AP1 QFN48-2.02 ZIF ISL-2
Added module: AP1 QFN56-1.02 ZIF CHIL-2
Added module: AP1 QFP64 ZIF FM3-1
Atmel/Microchip ATtinyxx2/xx4/xx6/xx7 (ISP-UPDI), added support
Module AP1 QFP48 ZIF STM32-3 set as a replacement for module AP1 QFP48 ZIF STM32-2 and an alternative for module AP1 QFP48 ZIF STM32
Module AP1 TQFP64 ZIF AVRmega-2, update of SW interface
Renesas R5F1026Ax (ISP), added support
TI (TMS) RM44L920APGET [LQFP144], power-on procedure improved
TI (TMS) RM46L830CPGET [LQFP144], power-on procedure improved
Analog Devices ADUC7026xxxx62 [LQFP80], programming/erasing bug fixed
Atmel/Microchip AT32UC3A3 family in LQFP144/ISP, programming fuse bits error for revisions earlier than 7
Intel E28F016SA [TSOP56], programming bug fixed
Macronix MX66U1G45GXDx54 [BGA24] (Quad I/O), Verifying Status Register - error! fixed
Micron MT29F64G08AECABH1-10IT [VBGA100], chip #1 problem fixed
TI (TMS) XMS432P401M [PQFP100], MSP432P401M [PQFP100], device size bug fixed
New software - Version 3.61
Postby Dataman (Daniel Smith) » 14 Sep 2020 15:28
