Fixed dimensions of some warning and error messages displayed from PG4UWMC, to correctly handle dimensions of message text
In PG4UWMC fixed Serialization From-file for large files (over 1MB of size)
Added adapter: DIL48/QFN32 ZIF Z8F-1
Added adapter: DIL48/QFN40-1.02 ZIF LT-1
Added adapter: DIL48/WLCSP25-4 ZIF-CS CY-1
DIL48/QFP100-1.02 ZIF xPC5x-1, AutoYes pins list correction
DIL48/LQFP64 ZIF xPC5x-2, AutoYes pins list correction
TI (TMS) RM44L920APGET [LQFP144], power-on procedure improved
TI (TMS) RM46L830CPGET [LQFP144], power-on procedure improved
Analog Devices ADUC7026xxxx62 [LQFP80], programming/erasing bug fixed
Atmel/Microchip AT32UC3A3 family in LQFP144/ISP, programming fuse bits error for revisions earlier than 7
Intel E28F016SA [TSOP56], programming bug fixed
Macronix MX66U1G45GXDx54 [BGA24] (Quad I/O), Verifying Status Register - error! fixed
Micron MT29F64G08AECABH1-10IT [VBGA100], chip #1 problem fixed
TI (TMS) XMS432P401M [PQFP100], MSP432P401M [PQFP100], device size bug fixed
New software - Version 3.61
Postby Dataman (Daniel Smith) » 14 Sep 2020 15:29
