ISP connection to a NEC70F3379 ISP diagram doesn't make sense
tomanycars
Postby tomanycars » 22 Aug 2021 15:35
hi
I am attempting to connect to a NEC70F3379 , it is listed in the Dataman library....
I have included a picture of the connections i require , but the connections in the Dataman library are really complicated and i am struggling to match up some of the the Datamans connections with the target chip. so here we go.
so i have attached two pictures one which shows the target Chip ( connections i need), the NEC703379 , and the connection diagram from the Dataman (data man adjustment) which is rather complicated to make sense of. , i have decipher the ones i can match up the connections , but there are afew that don't seem to make any sense to the manufactures connecting pins , so i just needed clarification on it. i have tried afew different ways to read the target chip but it doesn't respond.
any help would be great
thanks in advance
data man adjustment
connections i need
tomanycars
Re: ISP connection to a NEC70F3379 ISP diagram doesn't make sense
Postby tomanycars » 22 Aug 2021 15:43
UPDATE
I have attempted to connect with another programmer. and it reads the chip and brings back data... so i am confident that my soldering skills are ok. and the soldering locations i have are fine.
tomanycars
Postby tomanycars » 22 Aug 2021 21:08
UPDATE 2:
I have done further checking and the Dataman programmer periodically comes up with a variety of errors from lack of voltage & or to much voltage. and then it follows saying a message about please contact manufacturer , I have tested the ISP & the ZIF socket with the test tools & it comes back as ok.
I had a thought is the ISP connection pin arrangement is it for the wire attached or is that for the front only. i thought id ask the unlikely. at the moment anything seems a plausible question.
thanks
tomanycars
Postby tomanycars » 23 Aug 2021 14:45
UPDATE 3
I have another job which requires me to take a image dump of another NEC chip. which is a NEC 70F3632 , i figured i would give that ago while i was there. i have the connection diagram and attempted to connect via ISP , as removal is not possible.
and the errors are much the programmer comes up with a variety of errors , i try on another programmer and no errors at all. , very strange
Postby Dataman (Neil Parker) » 23 Aug 2021 14:51
Hello tomanycars,
Are you able to provide the info-rich problem report showing the mentioned error messages for analysis?
Help > Create problem report
tomanycars
Postby tomanycars » 23 Aug 2021 15:02
Neil,
do you mean pictures etc ?
Postby Dataman (Neil Parker) » 23 Aug 2021 15:24
Hello tomanycars,
Apologies, in the software there is the option "Create problem report" under the "Help" menu. Please generate a problem report and choose the option on the right. Please email the problem report to [email protected] for analysis.
tomanycars
Postby tomanycars » 23 Aug 2021 15:35
thanks i'll do that ,i can replicate the error on the NEC 70F3632 chip i need to image only due to fact its still here , the other one i created this post on the form has been packed for shipping.
i take it i have to reconnect and then perform the connection and then that will record it?
tomanycars
Postby tomanycars » 23 Aug 2021 15:38
Niel ,
i have had a quick look i think i understand how it works now , i'll send it over too the support email.
Return to “Dataman 40Pro”
