New software - Version 3.72
Postby Dataman (Daniel Smith) » 29 Nov 2021 10:44
Atmel AT45DB161B [TSOP28], alternative programming adapter DIL28/TSOP28 ZIF 11.8mm SFlash-1 acceptance added
Users browsing this forum: No registered users and 11 guests
