Added module: AP1 BGA100-1.02 ZIF eMMC-1
Added module: AP1 BGA144-9 ZIF STM32-1
Added module: AP1 QFN32-1.02 ZIF FL-1
Added module: AP1 QFP128-1.02 ZIF M16C-1
Added module: AP1 QFP144 ZIF STM32-2 (LD)
Added module: AP1 QFP48 ZIF STM32-3 (LD)
Added module: AP1 SOT23-6 ZIF TP-2
ISSI IS25WP032D-J [USON8 4x3] (Quad I/O), IS25WP032D-J [USON8 4x3], added support for 48Pro2AP, 448Pro2AP, 448Pro2AP-AU
Puya Semiconductor P25Q80H [SOP8-150] (Quad I/O), added support for 48Pro2AP, 448Pro2AP, 448Pro2AP-AU and read operation improved
AP1 SOT23-6 ZIF TP-2, fixed incorrect checking of serial number
New software - Version 3.72
Postby Dataman (Daniel Smith) » 29 Nov 2021 10:47
