Added adapter: BGA-Bottom-412 + BGA-Top-406 ZIF-CS
Added adapter: BGA-Bottom-537
Added adapter: DIL24/BGA24-2.02 ZIF HFlash-1
Added adapter: DIL48/BGA100-1.02 ZIF eMMC-2
Added adapter: DIL48/DSBGA40-1 ZIF-CS MSP430-1
Added adapter: DIL48/module ZIF BT-1
Added adapter: DIL48/PQFN41 ZIF IMM-1
Added adapter: DIL48/QFN24-1.02 ZIF IS31-1
Added adapter: DIL48/QFN40-1.02 ZIF LT-3
Added adapter: DIL48/QFN40-1.02 ZIF TPS40-2
Added adapter: DIL48/QFN40-2.02 ZIF ISL-5
Added adapter: DIL48/QFN56-2.02 ZIF ZL3-1
Added adapter: DIL48/QFP100 ZIF STM32L5-1
Added adapter: DIL48/QFP100-1 ZIF NEC-9
Added adapter: DIL48/QFP64-1.02 ZIF R7FA-2
Atmel AT45DB161B [TSOP28], alternative programming adapter DIL28/TSOP28 ZIF 11.8mm SFlash-1 acceptance added
Macronix MX25U51245GXD [TFBGA24] (Quad I/O), alternative programming adapter DIL8/BGA24-2 ZIF SFlash-1b acceptance added
New software - Version 3.72
Postby Dataman (Daniel Smith) » 29 Nov 2021 10:52
