New software - Version 3.73
Postby Dataman (Daniel Smith) » 14 Jan 2022 16:12
Version 3.73 features the following amendments:
HEX file load, range of addresses listing fixed
Modified detection of the operating system version (for Windows 11)
Added adapter: DIL48/module ZIF PAN1780
Added adapter: DIL48/LQFP44 ZIF-CS R5F-1
Added adapter: DIL48/QFN32 ZIF STM32-2&GD32
Added adapter: DIL48/QFN32-2.02 ZIF M03x-1
Added adapter: DIL48/QFN40-2.02 ZIF BEK-1
Added adapter: DIL48/QFN48-1.02 ZIF LPC-1
Added adapter: DIL48/QFN48-1.02 ZIF STM32G4-1
Added adapter: DIL48/QFN48-2.02 ZIF ISL-2
Added adapter: DIL48/QFP100-1.02 ZIF-CS R5F-19
Added adapter: DIL48/QFP128-1.01 ZIF PLD-8
Added adapter: DIL48/QFP144-1.02 ZIF R7FS-1
Added adapter: DIL48/QFP176 ZIF STM32-3
Added adapter: DIL48/QFP176 ZIF STM32-3&GD32
Added adapter: DIL48/QFP52-2.05 ZIF-CS ST62-1
Added adapter: DIL8/QFN8-5.02 ZIF SFlash-1b
Atmel/Microchip AT32UC3L0128A [WLCSP49], device info modified
Atmel/Microchip AT90CAN128 and AT90USB1286/1287 in QFP64 and QFN64 package, device info modified
Atmel/Microchip ATmega1280/1281 series in QFP100 and CBGA100 package, device info modified
Atmel/Microchip ATmega128RFA1 [QFN64], device info modified
Atmel/Microchip ATmega165/169/325/329/645/649 series in QFP64 and MLF64 package, device info modified
Atmel/Microchip ATmega3250/6450/3290/6490 series in QFP100 package, device info modified
Atmel/Microchip ATmega48/88/168/328/P/PB (ISP-SPI), fuse bits programming procedure modified
Atmel/Microchip ATmega64/128 [QFP64], device info modified
Atmel/Microchip ATmega808/1608/3208/4808 [QFN32], package drawing updated
Atmel/Microchip ATSAMD20/D21/D10/D11/D09/DA1/C20/C21/HA1/R21/L21/L22/R34/R35/R30 series, loading of the UROW config bits from input hex file added
Atmel/Microchip ATSAMHA1 series, support for RWW area added
Atmel/Microchip ATxmega64B1/128B1 [VFBGA100], automatic yes parameters and device info modified
Cypress/Spansion S70FL01GSxxBxxC1 [BGA24] (QuadSPI), solo verification procedure improved
Elmos E520.24, change device name to E520.24A0
Fudan Microelect. FM25Q08B [SOP8-150], FM25Q16A, setting Protected memory modified
GigaDevice GD25Q80E [SOP8-150], verifying status register modified
GigaDevice GD25Q16C, GD25Q16E, setting Protected memory modified
Lattice ispPAC-POWR604/1208/1208P1, improving of pgm parameters according to the actual pgm spec
Lattice ispLSI1048EA [TQFP128], ispLSI2096E [TQFP128], improving of pgm parameters assignment
Macronix MX25U25645G [SOP16] (Quad I/O), added support with adapter DIL16W/SOIC16 ZIF 300mil SFlash-1b
Macronix MX66U2G45GXRx00 [BGA24] (Quad I/O), changed device name and backward project compatibility
Micron MT25QU256ABA8E [SO16W] (Quad I/O), added support with adapter DIL16W/SOIC16 ZIF 300mil SFlash-1b
Microchip PIC12F1822, PIC16F1828, hex file load improved
Microchip PIC24FJ256GB410, load/save hex file improved
Nordic nRF52xx, erasing algorithm improved
Nuvoton M482ZGCAE [QFN33], programming config bytes procedure improved
NXP MKV5xF1M0xLL24, load HEX file modified
Renesas R5F566xxxxFP, programming modified
Renesas R7F701400, R7F701442, programming DFM improved
Samsung KLMAG1JETD-B041 [FBGA153], added option "Adjust(if necessary) the parameter Device end automatically (according to PRV info read from the device)"
S26KL/S26KS/S26HL/S26HS HyperFlash series, logging of the devices Random Number added
S26KL/S26KS/S26HL/S26HS HyperFlash series, options for erase of non-volatile registers added
STMicroelectronics STM8AF6226, STM8AF6226TxSSS, add recognize of programming block size
TI (TMS) MSP430F235 [LQFP64], added skipping verify TLV during solo verify
TI (TMS) TPS40422, add special settings for ignore error(s)
Toshiba TC57256D, programming algorithm modified
XMC XM25QH80B, setting Protected memory modified
Adesto Techn. AT25PE16 [SOIC8-150], Unexpected error 1 [IEC:1, D:01]! fixed
Analog Devices ADUCM310, ADUCM320, reading device bug fixed
Atmel/Microchip ATmega328PB (ISP-SPI), programming the CFD fuse bit error bug fixed
Atmel/Microchip ATxmega64B1/128B1 [VFBGA100], pinout bug fixed
Lattice MachXO3D, load/save project bug fixed
Microchip PIC16F/LF15313, PICmicro checksum calculation bug fixed
S26KL/S26KS HyperFlash series, fixed read operation bug
STMicroelectronics STM32G0xx Device access configuration address range error bug fix
STMicroelectronics STM8TL5xxxx, power up sequence bug fixed
