PG4UWMC: General Options/Job Report, file name generation options extended
Added module: AP1 BGA176-3.1 ZIF STM32H7-1
Added module: AP1 QFN56-1.02 ZIF RTL-1
Added module: AP1 QFP176-1.02 ZIF R7FA-1
Added module: AP1 SSOP28-200 ZIF PIC-2
Added module: AP1 TQFP64 ZIF PIC-3
Macronix MX25L64356 [SOP16] (Quad I/O), MX25L64356 [SOP16], alternative programming module AP1 SOIC16 ZIF 300mil SFlash-1b acceptance added
Microchip PIC18F15Q40 [VQFN20 3x3], added support
Microchip SST26WF064C [SOIC16] (QuadSPI), alternative programming module AP1 SOIC16 ZIF 300mil SFlash-1b acceptance added
Samsung KLMBG2JETD-B041 [FBGA153], added support PRV 0.3
Samsung KLMxGxJETD-B041 [FBGA153], stability of reading/verifying device improved
Silicon Laborat. MGM210P module, Device info modified
Silicon Works SW31100 [LQFP64], test ECC flags added
SST SST25VF032B [SOIC16], alternative programming module AP1 SOIC16 ZIF 300mil SFlash-1b acceptance added
Lattice LAXP2-5E/8E [csBGA132], LAXP2-5E/8E/17E [ftBGA256], pgm adapter assignment bug fixed
New software - Version 3.77
Postby Dataman (Daniel Smith) » 14 Jun 2022 10:17
Users browsing this forum: Semrush [Bot] and 4 guests
