PG4UWMC: General Options/Job Report, file name generation options extended
Added adapter: BGA-Bottom-434
Added adapter: DIL40/SSOP20-200 ZIF AS5-1
Added adapter: DIL48/BGA98-1 ZIF LPC-1
Added adapter: DIL48/LGA108-1 ZIF LTM-3
Added adapter: DIL48/module ZIF-CS MS88SF2
Added adapter: DIL48/QFN48-4.02 ZIF LT-1
Added adapter: DIL48/QFN60-1.02 ZIF ISL-1
Added adapter: DIL48/QFP100-1.02 ZIF A34-1
Added adapter: DIL48/QFP100-1.02 ZIF STM32G-1
Added adapter: DIL48/QFP128-1.01 ZIF ARM-1
Added adapter: DIL48/QFP48-1.02 ZIF LPC-5
Added adapter: DIL48/QFP64-1.04 ZIF R5F-19
Samsung KLMBG2JETD-B041 [FBGA153], added support PRV 0.3
Samsung KLMxGxJETD-B041 [FBGA153], stability of reading/verifying device improved
Silicon Laborat. MGM210P module, Device info modified
Silicon Works SW31100 [LQFP64], test ECC flags added
Adapter DIL48/QFP176-1 ZIF TMS320-2a, Automatic YES! bug fixed
Adapter DIL48/TSSOP16-170 ZIF R5F-2, Automatic YES! bug fixed
Adapter DIL8/BGA24-2 ZIF SFlash-1b, interface bug fixed
Lattice LAXP2-5E/8E [csBGA132], LAXP2-5E/8E/17E [ftBGA256], pgm adapter assignment bug fixed
New software - Version 3.77
Postby Dataman (Daniel Smith) » 14 Jun 2022 10:18
