Configuration bit programming in ISP in PIC16LF627A is incorrect
andrew96
Postby andrew96 » 28 Sep 2022 10:45
Hi Neil
got a bit of a weird one, If I program the PIC16LF627A via the zif socket.... all is well program works well
when I do so via ISP with the same file, programmer confirms verify is good!, but chip does not work!
so I put chip back in the programmer ZIF socket and do a verify... It says its different! the config bits at 2007, but that's the only error, its programming the rest of the chip fine
so that's why the chip no longer functions!
L2539: ADDRESS DEVICE BUFFER
L2540: -----------------------
L2541: 00002007 3F90 2110
the config bits are set the same (using the same file) when programming ZIF and ISP (and LVP is set)
what am I doing wrong? I have the programmer to program all areas, (program, config and eprom) its just the config bits that don't match!
thankyou
Andrew
Re: Configuration bit programming in ISP in PIC16LF627A is incorrect
Postby Dataman (Neil Parker) » 28 Sep 2022 11:00
Hello andrew96,
I am unable to recreate the situation you describe using our sample. Can I ask you to recreate the situation you describe and then generate a problem report (Help > Create problem report) and send it to me ([email protected]) for analysis?
andrew96
Postby andrew96 » 28 Sep 2022 11:29
Hi Neil,
I have a batch of 4 here, 3 show this behaviour and one is fine! so it looks like 3 chips are faulty when programming ISP. very weird! think I should buy some more!
Many thanks for looking into this for me, it seemed odd!
cheers
Andrew
andrew96
Postby andrew96 » 29 Sep 2022 20:32
Hi
Just to finish this off...
today I got some brand new ones and all is good!
I was convinced I must have been doing something wrong!
Cheers and thanks again
Andrew
Return to “Dataman 48Pro2”
