New software - Version 3.81
Postby Dataman (Daniel Smith) » 25 Nov 2022 16:20
Added module: AP1 QFN28-8.02 ZIF STM32G-1
Added module: AP1 QFP144 ZIF PLD-6
Added module: AP1 QFP48 ZIF STM32G-1
Added module: AP1 QFP64-1.02 ZIF R5F-14 (LD)
eMMC devices, register value "Write Counter" added into log window
Gowin Semicond. GW1N-UV4 [LQFP144], usercode programming improved
Gowin Semicond. GW1N-LV4 [LQFP144], GW1N-UV4 [LQFP144], corected device name, package name to LQ144
Intel/Altera 5M1270Z [FBGA324], improving of overcurrent protection system
Intel/Numonyx/Micron PC28F128J3F [Easy BGA64], read of Protection register improved
Intel/Numonyx/Micron PC28F128J3F [Easy BGA64], verification of Protection register improved
Macronix MX25UM51245GXDx00 [BGA24] (Octa I/O), added support
Module AP1 BGA24-2 ZIF SFlash-1b enabled as an alternative for all serial Flash
Module AP1 QFN8-4 ZIF SFlash-1, insertion test improved
STMicroelectronics STM32G031GxU [UFQFPN28], STM32G071GxU [UFQFPN28], STM32G081GBU [UFQFPN28], added support
STMicroelectronics STM32G030CxT [LQFP48], STM32G070CBT [LQFP48], STM32G071CxT [LQFP48], STM32G0B0CET [LQFP48], STM32G0B1CCT [LQFP48], added support
Microchip ATF1504ASV [TQFP44], pgm parameter assignment bug improved, Unexpected error 1 [IEC:1, D:1D]! fixed
NXP LPC55S69 [HTQFP64], incorrect size of device fixed
TI (TMS) LMK03328 [WQFN48], Unexpected error 1 [IEC:1, D:1A] bug fixed
