Serial Flash devices in QFN8 8x6mm package supported, TurboMode is available
Serial Flash devices in SOIC16 300mil package supported by module AP1 SOIC16 ZIF 300mil SFlash-1a, TurboMode is available
AP1 TSOP48 ZIF 18.4mm NAND-3, TurboMode support indication fixed
New software - Version 3.04
Postby Dataman (Daniel Smith) » 03 Mar 2014 14:20
