New software - Version 2.68
Postby Dataman (Daniel Smith) » 15 Nov 2011 12:43
Atmel AT25DF041A, programming bug fixed
Atmel AT91SAM9XExxx, info about required converter updated
Freescale ColdFire MCF52xxx family, programming/reading speed increased
