Module AP1 SOIC8 ZIF 200mil SFlash-1a, TurboMode allowed
Automatic YES for module AP1 SOIC16 ZIF 300mil SFlash-1a bug fixed
New software - Version 3.05
Postby Dataman (Daniel Smith) » 10 Apr 2014 15:31
