Version 3.85 features the following amendments:
PG4UWMC: fixed PG4UWMC software exception "Permission denied (#10013 in Bind)" bug during searching programmers
Added adapter: BGA-Bottom-556
Added adapter: BGA-Top-384a ZIF
Added adapter: DIL48/BGA121-5 ZIF NAND-1
Added adapter: DIL48/BGA40-AM30LV ZIF-CS NAND-1
Added adapter: DIL48/BGA48-10 ZIF nvSRAM-1
Added adapter: DIL48/QFN35 ZIF TPS-2
Added adapter: DIL48/QFP64-1.02 ZIF APM32-1
Added adapter: DIL48/QFP64-1.02 ZIF CY-4
Added adapter: DIL48/QFP64-1.02 ZIF R5F-8
Added adapter: DIL48/WLCSP144-1 ZIF STM32-1
Analog Devices ADM1260, erase procedure improved
Atmel/Microchip ATtinyxx4/xx6/xx7 in ZIF and (ISP), Power-on sequence modified, effectiveness improved
Atmel/Microchip ATmega3208/3209/4808/4809 family, Power-on sequence modified, effectiveness improved
Atmel/Microchip devices using UPDI, work with the devices improved. Some fuse settings cause failures
cFeon(Eon Si.Sol.) EN25QX128A(2V) [SOP8-208] (QuadSPI), EN25QX128A(2V) [SOP8-208], changed device name and backward project compatibility
Cypress/Infineon S6J334DJTxxxx [TEQFP176], power-up procedure improved
Eon Silicon Sol. EN25QX128A(2V) [SOP8-208] (QuadSPI), EN25QX128A(2V) [SOP8-208], changed device name and backward project compatibility
ESMT EN25QX128A(2V) [SOP8-208] (QuadSPI), EN25QX128A(2V) [SOP8-208], changed device name and backward project compatibility
ICT PEEL22VC10A, improving of overcurrent protection system
Infineon TC2xx, TC3xx devices, power-up procedure improved
Infineon S29JL032HxxTxx31 [TSOP48] (erase test), Erase procedure modified
Infineon SAK-TC212L-8F133F AC (ISP-DAP), add info to LOG
Lattice ispLSI2128VE [TQFP100], improving of overcurrent protection system
Microchip AVR DA/DB family, Power-on sequence modified, effectiveness improved
Microchip/Atmel PLD devices, improved device info with decoupling capacitor value
Micron MT25QU512ABA8E12 [TBGA24] (Quad I/O), MT25QU512ABA1E12 [TBGA24] (Quad I/O), MT29FxG01ABxxD (and other manufacturer devices based on them), internal improvement (related to plane select bit treatment)
Nuvoton NUC1xx, NUC2xx, programming Config registers improved
Nuvoton NUC1xx (ISP), verifying device improved
NXP LPC8xx, in Code read protection (CRP) added NO_ISP level
Renesas R5F564MxxxFC, R5F564MxxxLK, added programming of Data area and Option area
Renesas RX130 group blank, read and verify operations allowed
Renesas/IDT 5P49V6965A000, reliability of programming improved
STMicroelectronics STM32G4 series, programming method changed (introduced modes program all data, only data from file, only nonblank data; discarded mode program selected pages)
STMicroelectronics STM32H7xx, modified IWDGx option bits description
STMicroelectronics STM32H7xx, modified verify algorithm for speed improve
Texas Instruments LM4Fxxx [LQFP64]/TM4Cxxx [LQFP64]/XM4Cxxx [LQFP64], power-up sequence modified and programming procedure speed-up
Texas Instruments RM42L432BPZT [LQFP100], erase procedure improved and overall device algorithm optimization
Texas Instruments RM48L952DZWTT [NFBGA337], operation algorithms improvements
Texas Instruments TMS320F28069 [LQFP80], erase procedure improved
TI (TMS) TPS65086100, programming procedure improved
Analog Devices ADM1266, load/save project bug fixed
DIL48/QFP100-1 ZIF HCS08-1, adapter interface bug fixed
Infineon SAK-TC212L-8F133F AC (ISP-DAP), EC: 0007 bug fixed
Infineon SAK-TC212L-8F133F AC [TQFP80] (DAP), ID check bug fixed
Renesas R5F564MxxxLK, programmer configuration bug fixed
STMicroelectronics STM32C0, STM32G0 and STM32L4 series, fixed check of possible conflicts with protections active in device before programming
STMicroelectronics STM32G4 and STM32L4 series, fixed possible problems if dual-bank mode was changed in menu, but the menu changes were cancelled
STMicroelectronics STM32H7xx, RDP erase bug fixed
XTX XT25F16B [USON8 2x3], pinout bug fixed
New software - Version 3.85
Postby Dataman (Daniel Smith) » 04 May 2023 11:00
