New software - Version 3.11
Postby Dataman (Daniel Smith) » 20 Jan 2015 21:22
Added support of AP1 BGA48-1.01 NOR-1 module
Added support of AP1 LFQFP80 ZIF RX-1 module
Added support of AP1 QFP100 ZIF PLD-17 module
Added support of AP1 QFN20-1 ZIF STM8-2 module
Added support of AP1 QFP64-1 ZIF STM8-1 module
Added support of AP1 QFP64-1 ZIF TMS320-1 module
Spansion S71VS128RB0AHK0L [FBGA56], power-up sequence modified for AP programmers
Spansion S71VS128RB0AHK4L [FBGA56], power-up sequence modified for AP programmers
