New software - Version 3.13
Postby Dataman (Daniel Smith) » 30 Mar 2015 15:52
Automatic YES! for AP1 QFP100 ZIF PLD-17 module fixed
Automatic YES! for more Parallel NOR flash AP1 modules fixed
