New software - Version 3.15
Postby Dataman (Daniel Smith) » 04 Jun 2015 16:06
Version 3.15 features the following amendments:
Information about missing or corrupted keyfile.val modified
In PG4UWMC added option of starting programmer Sites one by one, by menu command "Site #n | Refind programmer"
In PG4UWMC fixed information about minimal required RAM memory in warning message displayed on computers, that have not enough RAM installed, to match minimal system requirements for programmer control software PG4UW/PG4UWMC
Added support of AP1 BGA52-1.1 NOR-1 module
AMD/Lattice/Vantis PALCE22V10H/4, improving of power-up procedure
Analog Devices ADUC7026xxxx62, programming algorithm improved
Atmel ATmega128 (ISP-SPI), power-up procedure modified
Atmel ATmega16/ATtiny13/V (ISP-SPI)(Enhanced), Calibration procedure modified
BGA-Top-224 ZIF adapter name changed to BGA-Top-224 ZIF-CS
Freescale Semic. MKL17Z256 [QFN32], programming algorithm improved
Microchip PIC24FxxKAxxx, PIC24FVxxKAxxx, power-up procedure modification
Nec/Renesas uPD78F0058Y, erase procedure improved
Spansion S25FL128S, modification of items in Programming parameters and Special options
Spansion S25FL256SxxMxx00 [SO16], improving of power up/down procedures
Spansion S29GL128PxxTxxV1 [TSOP56]x16, power-up procedure modified
STMicroelectronics STM8AF6246U [VFQFPN32], configuration improved
STMicroelectronics STM8AF6246U, Automatic YES! improved
Adesto Techn. AT25DQ161, Alt+S menu bug fixed
Altera EPCS64/128, EPQC32/64/128, POF file save bug fixed
Atmel AT89LP6440 (ISP), AT89LP3240 (ISP), communication error bug fixed
Atmel ATSAM4S in LQFP100 packages, power-up procedure bug fixed
Atmel AVR8 (ISP-SPI) devices, compatibility of projects saved in software versions 2.75i to 2.91 bug fixed
DIL48/PLCC44 ZIF-CS TK68HC-1, adapter bug fixed
Freescale Semic. MK10DX64VLH5 [LQFP64], programming/verify bug fixed
GMT G2510, verify error bug fixed
Microchip PIC18FxxJ50, PICmicro checksum calculation bug fixed
Microchip PIC32MX1xxFxxB/D, PIC32MX2xxFxxB/D,"Description of ISP connector pins" in Ctrl+F1 for (ISP-4wire JTAG) and (ISP-4wire JTAG-ext.VDD) devices bug fixed
NEC uPD70F3632, intialization procedure bug fixed
NXP LPC11C22, programming algorithm bug fixed
NXP LPC4357, programming "Active Boot Flash Bank" bug fixed
SK Hynix H26M52103FMR [FBGA153], boot size fixed
STMicroelectronics STM32F205ZE (ISP-JTAG), Unexpected error 1 [IEC:3, D:85] problem solved
TI (TMS) CC2530, programming algorithm bug fixed
Users browsing this forum: No registered users and 17 guests
