New software - Version 3.96
Postby Dataman (Daniel Smith) » 10 Sep 2024 11:00
Version 3.96 features the following amendments:
Added module: AP1 QFN56 ZIF MP-1
Added module: AP1 QFP176-1.02 ZIF TMS320-3
Added module: AP1 WLCSP25-5 ZIF STM32-1
Alliance Memory ASFC8G31M-51BIN [FBGA153], identification procedure improved
Analog Devices/Linear Technology LTCxxxx, LTMxxxx, Data Pattern CRC-32 added into log window, after loading file
AP1 QFP32-1.04 ZIF N32-1, Automatic Yes! parameters modified
Atmel/Microchip ATtiny25/45/85/V, Calibration options modified
Azoteq IQS227AS, IQS227B, verification procedure improved
Cypress Cy27410, power-up procedure modified
Espressif ESP32-S3-WROOM-1-N8Rx, insertion test modified
Infineon AURIX family, added unlock for debug interface
Infineon AURIX family, load hex file improved
Infineon AURIX family, power-up sequence improved
Infineon TC2xx/TC3xx series, initialization procedure improved
Infineon XDPE152C4D, programming procedure improved
ITE Tech. Inc. IT5571E-xxx, stability of enter into programming mode improved
Lattice LC4064V [TQFP100], overcurrent limit increased
Macronix MX26LV160, chip erase modified
Macronix MX66L2G45GXR [BGA24] (Quad I/O), MX66U2G45GXRx00 [BGA24] (Quad I/O), read operation improved
Micron MT25QL02GCBB8E12 [TBGA24] (Quad I/O), read operation improved
SkyHigh Memory S34ML04G300Bxx10 [BGA63] (AML-03), Check Max. Allowed Number of Invalid Blocks in Device feature added
STmicroelectronics STM32G0xx and STM32C0xx, option bytes programing and erase modified
STmicroelectronics STM32G4xx, option bytes programming modified; RDP lvl1 default value changed to $BB
Toshiba TMPM368FDFG [QFP100], erase procedure modified
Winbond W25Q01JVxxxQ [SOIC16-300] (QuadSPI), power-on procedure improved and current fuse level improved
Winbond W25Q40RLxxxQ [SOIC8-200] (QuadSPI), W25Q12PWxxxM [SOIC8-208] (QuadSPI), W25Q12PWxxxM [SOIC8-208], Alt+S menu improved
Altera EPCS/EPCQ family, Programming adapter test - error! fixed
Atmel/Microchip ATtiny13/V/A (ISP-SPI), Bad calibration values displayed in Calibration tab bug fixed
Atmel/Microchip ATtiny25V (ISP-SPI), Flash programming bug fixed
eMMC devices, programming PRODUCT_STATE_AWARENESS_ENABLEMENT register bug fixed
Lapis ML62Q1xxx, General info in CTRL+F1 window fixed
Macronix MX29LV640EB [TSOP48], sector group(s) protect/unprotect bug fixed
Serial NAND 1.8V devices, support fixed in module AP1 QFN8-5.02 ZIF SFlash-1a
STMicroelectronics STM32G473, STM32G474, STM32G484, fixed interactive reaction to DBANK bit setting change in Device access configuration <Alt+S> menu (the restoration of original values was missing after returning from DBANK change to default state)
STMicroelectronics STM32, GigaDevice GD32, Geehy APM32, MindMotion MM32, 'Unexpected error 1 [IEC:1, D:10]!' fixed for devices with SWD interface only
STMicroelectronics STM32U5xx, BOOTADDxx registers masks bug fixed
Winbond W25H01NWTBxM-DTR [TFBGA24 6x8](QuadSPI), Unexpected error 1 [IEC:1, D:78]! bug fixed
Winbond W25Qxxx in TFBGA24 8x6mm (QuadSPI), Unexpected error 1 [IEC:1, D:78]! fixed
Users browsing this forum: Bing [Bot] and 1 guest
