New software - Version 4.05
Postby Dataman (Daniel Smith) » 11 Sep 2025 15:15
Version 4.05 features the following amendments:
Fixed Main Checksum calculation after calling remote control commands in remotelb.dll: SEND_CMD_LoadFileToSecondaryBuffer
Fixed Main Checksum calculation after calling remote control commands in remotelb.dll: SEND_CMD_LoadFileToSecondaryBuffer_CINDEX
Fixed Main Checksum calculation after calling command line parameter: /Loadfiletosecondarybuffer
Added module: AP1 BGA144-16 ZIF ITE-1
Added module: AP1 QFN48-2.02 ZIF nRF-6
Added module: AP1 QFN52-1.02 ZIF BPD9-1
Added module: AP1 QFP144-1.02 ZIF STM32-USBPHY-1
Analog Devices MAX20816B [TQFN56-7x7] (RailA+RailB), programming procedure improved
Analog Devices MAX22216 [TQFN32], programming procedure improved
Atmel/Microchip ATSAME70Q21A, initialization sequence improved
Cypress 25HL01GTPx01 [SOIC16] (QuadSPI), changed device name and backward project compatibility
Espressif ESP32-C3, programming and verification of eFUSE area improved
Fujitsu/Cypress/Spansion/Infineon MB90F352Exxx, Device info updated
GigaDevice GD25B512MFBxR [TFBGA24], GD25B512MFBxR [TFBGA24] (QuadSPI), Dummy Cycle setting added to "Special options" window
Infineon 25HL01GTPx01 [SOIC16] (QuadSPI), changed device name and backward project compatibility
Infineon S25FL128LxxMxx01, Verifying Status and Configuration Registers modified
ISSI IS25LP512MG-RH [TFBGA24] (Quad I/O), verify procedure modified
Macronix MX25UM25645GMx00 [SOP16] (Octa I/O), improved device pinout
Macronix MX25UW family, Alt+S menu improved
Microchip AVRDA/DB/DU/EA/EB family, programming routines slightly modified
Microchip dsPIC33EPxxxGP5xx/PIC24EPxxxGP2xx, modification of programming the Configuration bits
Micron MT25QU128ABA1E [DFN8 6x5] (Quad I/O)(FL-01), MT25QU128ABA1E [DFN8 6x5](FL-01), programming parameters improvement
NXP/Philips LPC21xx, power-up procedure improved
Parade TT7001TQFP128ITR2-A1 [QFP128], Insertion test modified
Rohm BR25H128FJ-2AC [TSSOP-B8], change of device name suffix to BR25H128FVT-2AC [TSSOP-B8]
Silicon Laborat. EFM32PG23 devices, Initialize procedure improved
Silicon Laborat. EFM32PG23 devices, "Full chip erase" procedure improved
STMicroelectronics STM32WB1x devices, programming algorithm modified
STMicroelectronics STM32WB5x devices, programming algorithm modified to support FUS 2.x.x
Winbond W35N01JWTB [TFBGA24], partname extended to W35N01JWTBxT [TFBGA24]
Alliance Memory AS5F31G04SND-08LIN [WSON8], device name fixed to AS5F31G04SND-08L [LGA8]
Ember/Silicon Labs. EM35x, erasing and programming procedure bug fixed
Geehy APM32F405RGT [LQFP64], APM32F407RET [LQFP64], APM32F407RGT [LQFP64], APM32F415RGT [LQFP64], pinout fixed
Macronix MX25U12832F [SOP8-200], reading/verification procedure bug fixed
Microchip PIC18Fxx20/PIC18LFxx20 (ISP-ext.VDD), programming procedure bug fixed
Micron MT29F8G08ADAFAWP-AAT [TSOP48] (EPS-22), project checksum problem fixed
MindMotion MM32F0020B1T [TSSOP20], MM32F031KxU (n4) [QFN32], option bytes programming fixed
Module: AP1 BGA153-1.01 eMMC-1, HW error by pgm socket initialization bug fixed
ON Semiconductor CAT/CAV/NV25128xxxx (ISP), description of ISP connector pins bug fixed
STMicroelectronics STM32H7xx, option bytes verify bug fix
STMicroelectronics STM32L071RBH [TFBGA64], STM32L072RBH [TFBGA64], STM32L073RBH [TFBGA64], STM32L083RBH [TFBGA64], Main memory size fixed
STMicroelectronics STM32WBxx devices, erase before programming fixed
TI (TMS) TPS66993U, TFUc command bug fixed
