New software - Version 3.20
Postby Dataman (Daniel Smith) » 11 Dec 2015 16:20
Added support of AP1 QFN48-1.01 ZIF PX8-2 module
Added support of AP1 QFN68 ZIF CY-2 module
Added support of AP1 QFP144 ZIF H8S-6 module
Micron MT29F4G08ABADAWP-IT [TSOP48], Empty Site for AP1 TSOP48 ZIF 18.4mm NAND-3 problem fixed
