New software - Version 3.23
Postby Dataman (Daniel Smith) » 08 Apr 2016 14:25
Version 3.23 features the following amendments:
Fixed error "Project loading error!" with "Main buffer data checksum mismatch!" that sometimes could occur in Multiprogramming systems and some special devices
Improved handling in Warning window for low credits value of Credit box
Improved handling in Warning window for programming adapters lifetime counter
In PG4UWMC fixed bug in "Search for Programmers" dialog regarding new programmers configuration
Adapter DIL48/QFN56-2.02 ZIF CY-3, interface modified
Atmel AT89C51AC2 [VQFP44], programming procedure improved
Atmel AT89C51CC01, programming procedure improved
Atmel ATmega168PA [MLF32](SEM-1), ATmega644PA [MLF44](SEM-1), calibration firmware updated
Atmel ATmega644 (ISP-SPI)(Enhanced)/OSCCAL, calibration FW upgrade
Freescale Semic. MPC5645S [LQFP208], programming speed improvement
Fujitsu MBM29F002TC [PLCC32], added undocumented feature "SECTORS UNPROTECT"
GigaDevice Semic. GD25Q80B, added CMP bit and Security registers programming
Intersil/Zilker Labs ZL2106, programming procedure improved
Microchip PIC32MX330/350/370Fxxx, added set of configuration bits DEBUG
Microchip SST26VF032B, programming algorithm improved
Nuvoton N79E715 [SOP20], programming adapter assign corrected
Samsung S3FM02G (ISP), programming procedure improved
Spansion S25FS128sxxNxx00 [WSON8], changed device name and backward project compatibility correction
STMicroelectronics ST72F324BK6T [TQFP32], erase procedure improved
STMicroelectronics STM32, added Unique Device ID read
TI (TMS) CDCE72010, verify procedure modified
TI (TMS) UCDxxxx, add information about pull-up resistor
Adapter DIL40/QFP144 ZIF LPC-1, insertion test bug fixed
Atmel AT32UC3B064 [QFN64], unexpected error bug fixed
Atmel ATSAME70xxx, verify procedure bug fixed
Dallas/Maxim DS28E15, synchronization error, verify and programming bug fixed
Eon Silicon Sol. EN25QH16, OTP area operation bug fixed
Fujitsu MB90F345xxx [QFP100], programming procedure bug fixed
Infineon TLE983x, fixed bug in range check of edit component in dialog Alt+O
Linear Technology LTC2977, PMBUS_WRITE_EE_DATA and PMBUS_READ_AND_VERIFY_EE_DATA bug fixed
Microchip dsPIC33FJ32/64GS406/606/608/610, load hex file bug fixed
Microchip PIC18F2221/4221 [TQFP44], programming configuration bits bug fixed
Microchip PIC18F2x2/4x2, VBOR configuration bits bug fixed
Microchip PIC24FxxKA/KLxxx [QFN20], programming procedure bug fixed
Microchip PIC32MX Family, "Unexpected error 1 [IEC:0, D:00]!" bug fixed during programming operation
Microchip SST26VF032B [SOIC8], Unexpected error and Insertion Test bug fixed
Nuvoton N79E715 [SOP20], verification bug fixed
Primarion PX8xxxxx, "Unexpected error 1 [IEC:3, D:3C]" bug fixed
Renesas uPD70F3532, device overcurrent error fixed
Samsung S3FM02G (ISP), programming bug fixed
Seiko Instruments S-29x90AFJ, pin assignment bug fixed
STMicroelectronics STM32F446xx, option bytes verify bug fixed (if SPRMOD=1)
TI (TMS) RM42L432, ID check error fixed
TI (TMS) TPS53641 [QFN40], identification of adapter bug fixed
Winbond W25Q64FW, insertion test bug fixed
