New software - Version 3.24
Postby Dataman (Daniel Smith) » 13 May 2016 15:17
Fixed noncritical (visual) bug in the selftest without Diagnostic pod
Micron MT25QU512ABB8E [SO16W] (Quad I/O), added support
