New software - Version 2.66
Postby Dataman (Daniel Smith) » 15 Nov 2011 15:08
Version 2.66 features the following amendments:
Atmel AT90S8515, verify error fixed
Atmel ATxmega family, Blank check bug fixed
Atmel AVR32 family, autentification bug of converter (DIL48/QFN64 ZIF-CS XMEGA-1) fixed
Catalyst/On Semiconductor CAT25256, buffer size bug fixed
Coreriver/Gencore GC89C5x1, fixed device size information in "Device info" dialog
Coreriver/Gencore GC89L541A0, programming algorithm bug fixed
Freescale Semic. MC9S12XETxxx, algorithm instability problem solved
Freescale Semic., Motorola MC56F8xxx, fixed data dependent bug of algorithm
Freescale Semic., Motorola MC68HC908JBxx, algorithm bug fixed
Freescale Semic., Motorola MC68HC908JBxx (ISP 5-wire), algorithm bug fixed
Lattice ispLSI2032 [PLCC44], pin assignment bug fixed
Macronix MX29LV640DT [PSOP44], programming algorithm bug fixed
Microchip PIC16F68x, power-down procedure bug fixed
Microchip PIC24FJxxx Family, power-up procedure bug fixed
Numonyx NAND04GW3B2DN [TSOP48], insertion test bug fixed
Numonyx PC28F00AM29EWL, sporadical overcurrent error fixed
Numonyx PC28F512M29EWH [BGA64], unexpected error solved
NXP/Philips LPC1767 (ISP) and LPC1768 (ISP), buffer size bug fixed
PMC/Chingis Pm49FL004T [TSOP32], insertion test routine bug fixed
Spansion S29GL128PxxFxx02 [FBGA64]x16, verification procedure bug fixed
STMicroelectronics STM8S105C4T [LQFP48] package drawing bug fixed
Zilog ZLP32300S2832, serialization function bug fixed
NAND flash devices, fixed insertion test problem when switching from 48Pro2 to 48Pro+
NAND flash devices, fixed problem with incorrect User Area settings recommendation when in project mode
Altera EPCSxxx, adding of information about improving of stability during programming actions
AMD/Lattice/Vantis MACH211SP (ISP), adding of information about improving of stability during programming actions
AMD/Lattice/Vantis PALCE610H, improving of overcurrent protection system
Atmel AT25DF041A (ISP), added "Erase before programming" option
Atmel ATtiny10, power_off sequence modified
Coreriver/Gencore GC89L541A0, programming algorithm improved
Cypress CY37128 [PLCC84], improving of overcurrent protection system
Cypress CY8C20466 [QFN32], power-up sequence modification
Freescale Semic./Motorola MC908QC16 (ISP 5-wire), minor power on/off sequence improvements
Fujitsu MB90F598G, added new feature 'Security' to device option
Hitachi HD6473837F [QFP100], HD6473837E [QFP100], HD6473837UF [QFP100], change programming adapter to DIL32/QFP100 ZIF HS3836ESF01H
Maxim MAXQ610 [TQFN32], programming algorithm improved
Microchip PIC16C63A, PICMicro checksum calculation added
Microchip PIC18F2520, power-on procedure improved
NEC uPD78F0078, uPD78F0078Y, programming speed increased
Numonyx PC28F256P30BF [EasyBGA64], block unlock procedure improved
Numonyx PF38F5060M0Y3DF [SCSP56] (BEFP), read/verify operation stability improved
Renesas Technology R5F21257SDFP (ISP-single wire), all operation speed increased and support only with module ISP-1-20
Spansion S29GL128PxxFxx02 [FBGA64]x16, verification procedure improved
Spansion S29GL512PxxFxx01 [FBGA64]x16, verification procedure improved
SST SST25VF016B, programming speed increased
STM8 devices, added checksum calculation for each area
SyncMOS SM5964, programming algorithm improved
Texas Instruments MSP430F2001, skip verify DCO added (for verify procedure)
Added support of x2708 memory family for MemProg2 programmer
LGE-15~18 customized algorithms modified upon customer request
Adapter DIL48/QFP64-3 ZIF NEC-2, interface improvement
Improved initialization for BGA socket converters with BGA-Bottom-125 board
