New software - Version 3.25
Postby Dataman (Daniel Smith) » 27 Jun 2016 10:40
Added support of AP1 BGA153-1.01 eMMC-1 module
Added support of AP1 QFN40 ZIF CC-1 module
Added support of AP1 QFP144 ZIF PLD-1 module
Added support of AP1 QFP144 ZIF PLD-2 module
Added support of AP1 QFP32-1 ZIF STM8-1 module
Added support of AP1 QFP48-1 ZIF STM8-1 module
Added support of AP1 QFP64 ZIF PLD-1 module
Added support of AP1 TSOP48 ZIF 18.4mm NOR-4 module
