Fixed dialogs "Statistics" and "Password" in Pg4uwMC standalone programmer mode to display and control them correctly on built-in LCD and touchscreen
New software - Version 2.81
Postby Dataman (Daniel Smith) » 15 Nov 2011 16:50
