Winbond W39V040B, erase procedure bug fixed
Renesas R4F2461, bug fixed
SST SST25WFxxx, Atmel AT25DF081, removed from support
New software - Version 2.49
Postby Dataman (Daniel Smith) » 16 Nov 2011 12:14
