New software - Version 2.57
Postby Dataman (Daniel Smith) » 16 Nov 2011 12:20
Version 2.57 features the following amendments:
Anachip/ICT PA7540JN [PLCC28], pin assignment bug fixed
Boot mode bug fixed for STR75x devices
Hynix HY27US08121B [TSOP48] (LGE-02), redirection table verification bug fixed
Microchip PIC10Fxxx, power-up procedure bug fixed
Microchip PIC10F220, PIC10F222, configuration fuses bug fixed
Zilog Z86E02/04/08, save option bits in project bug fixed
NXP/Philips LPC2387 [LQFP100], algorithm bug fixed
Microchip PIC18F87J50, power-up procedure bug fixed
NEC uPD78F9418A, communication speed bug fixed
Atmel ATtiny25/45/85, clock settings bug fixed
Atmel AT90USB162/82, bootlevel settings bug fixed
Samsung K9F5608xxx [FBGA63], insertion test bug fixed
BGA-Bottom-12 (discontinued) and BGA-Bottom-148 adapters compatibility bug fixed
Microchip PIC18F45K20, PIC18F46K20, configuration fuses bug fixed
Microchip PIC32MX Family, programming bug fixed
SST SST39VF1601C, programming of User Security Area bug fixed
ST Microelectronics STM32F103T6xxA [VFQFPN36], pinout fixed
Microchip dsPIC33FJ64MC508 [TQFP80], Insertion test bug fixed
Atmel AT88SC0104C (ISP), buffer size and default Secure Code correction
Numonyx M28W320FCB, fixed problem with creating and consequent loading of project file(s)
Motorola MC68HC912D60 (ISP), ISP circuit design bug fixed
Macronix MX25L3237D [SOP16], pinout bug fixed
EM Microelectronic EM4276/4376 [MLF32] memory size bug fixed
Numonyx M39P0R9070E [FBGA105], programming bug of special areas fixed
Microchip dsPIC30Fxxxx, dsPIC33Fxxxx, PIC10Fxxx, PIC12Fxxx, PIC16Fxxx Family, PICmicro checksum calculation added
Winbond W39V040FB [PLCC32], power_up procedure improved
EM Microelectronic EM4176/EM4276/EM4376/EM6869, programming algorithm improved
Hynix HY27US08121B (LGE-01) [TSOP48] device name change to HY27US08121B [TSOP48] (LGE-01)
Azoteq IQS123, programing procedure improved
Atmel AT45DB642D, programming of Configuration register prior to programming of Flash
Freescale Semic. MC9S08QG8, programming improvement
STM PSD854F2V, programming algorithm improved
Finisar SFP, added option for password setting
Samsung K6x1008C2D [TSOP32], SRAM test modification
Cypress CY8C27443, power-up sequence modified
Xilinx XQ17xxx/XQR17xxx, improving of pgm. parameters assignment
AMD/Lattice/Vantis MACH435, improving of pgm. parameters assignment
Numonyx M28W320FC, block unprotect modified
STMicroelectronics M29F040B, verify algorithm improved
STMicroelectronics M29W160E, programming algo improved
Renesas R5F212BA, programming speed increased
LatticeXP [TQFP100/PQFP208/BGA256], improving of pgm. parameters assignment
Xilinx XC3S-AN, programming of Configuration register before programming of device
Excel Semiconduct. ES25Mxx, changed device names from ES25Mxx to ES25MxxA and backward project compatibility correction
Improved interface for BGA socket converter
Improved interface for converter DIL48/QFP100 ZIF PLD-13
Improved interface for converter DIL48/QFP144 ZIF MC56F-1
