Selftest procedure modified for test checking the Diagnostic pod
Micron MT25QL256ABA8E12 [TBGA24] (Quad I/O), added support
Micron MT25QL512ABA8E [SO16W] (Quad I/O), added support
New software - Version 3.26
Postby Dataman (Daniel Smith) » 29 Sep 2016 16:11
