Fixed positioning of some message boxes on standalone programmer LCD touchscreen
Fixed USB driver installation on standalone programmer systems with Windows 8 installed
New software - Version 3.26
Postby Dataman (Daniel Smith) » 29 Sep 2016 16:12
