New software - Version 2.78
Postby Dataman (Daniel Smith) » 18 Nov 2011 16:09
New in Pg4uwMC - improved function of "Search for programmers" to enable search for and use of multiple programmers together
Atmel ATxmega32D4P, ID fixed
