p87c51ubpn not in library
grover64
Postby grover64 » 28 Mar 2018 09:26
Hi there
I am trying to program a philips p87c51ubpn , but this type not in any library that i downloaded from the dataman site.
Is there another way to program it
Greatings grover
Re: p87c51ubpn not in library
Postby Dataman (Neil Parker) » 29 Mar 2018 09:49
Hello grover64,
Thank you for posting in our user forum. The Dataman S4 supports several different versions of the 87C51 device under the (S4 MCS-51 lib. V1.64) which also requires the MCS-51 Module.
Please try selecting the following algorithm under the Philips manufacturer:
If you need a simpler solution to programming the P87C51UBPN device then I would recommend the Dataman-40Pro Universal 40pin Programmer which comes with everything you need to read and program this device oithout the need for any additional modules.
I have you any questions, please do not hesitate to contact me.
Dataman programmers
grover64
Postby grover64 » 29 Mar 2018 11:22
hi
i have tried the LIB mcs-51 and the type 87C51 ,also ather type's in lib but no working prom , i have the module mcs-51
maybe i can program it with another brand and type prom!!!!!
greatings
Postby Dataman (Neil Parker) » 29 Mar 2018 12:04
Yes, you can try the other selections and see if the situation improves.
Can you provide any details about "but no working prom", does it fail to program? What error message do you get? Or does it program OK on the S4 but does not work in the application? Please sepcify and I will try to help.
Do you need to set the security bytes on this chip? This can be achieved using the FUNC > QUICK commands and then choosing the number of security bytes you want to set.
grover64
Postby grover64 » 30 Mar 2018 09:24
hi there
it program OK on the S4 but does not work in the application, even with the comp button (when i tried to copy hem from an working one ).
it even says SAME after pressing the comp button .... after i burn the prom.
greatings
Postby Dataman (Neil Parker) » 03 Apr 2018 11:47
Please read the master device into the S4 RAM, then send the RAM contents to the PC using the serial cable and S4 driver software. If you can then email the .hex or .bin file to [email protected] and I will take a look at the contents to try and determine if the master device is protected or not, if it is protected, then you will not be able to read or copy it.
Dataman programmers
Return to “Dataman S4”
