Fixed in PG4UWMC for standalone programmers - "Search programmer" dialog is now displayed correctly,
Fixed in PG4UWMC click on "Run what" button displays message containing information "what to do"
Fixed in PG4UWMC serialization numbers are now displayed for each programming Site also in mode of independent projects for each Site
Fixed in PG4UWMC serious hazard, that causes incorrect project data loading with result OK in situation, when previously loaded project was not successful due to error: "Invalid size or check sum of file or unsupported compression format - Native error: 00008"
Improved AP1 module error identification
Added module: AP1 PLCC32 ZIF NOR-1a
Added module: AP1 QFN24-1.02 ZIF MSP430-1
Added module: AP1 SOIC32 ZIF 445mil
Cypress CY7C53120E2 [SOIC32], CY7C53120E4 [SOIC32], added support
Echelon FT3120-E4 [SOIC32], added support
Renesas R5F10xx [SSOP20], added support
New software - Version 3.44
Postby Dataman (Daniel Smith) » 12 Oct 2018 14:27
