New software - Version 3.44
Postby Dataman (Daniel Smith) » 12 Oct 2018 14:27
Improved AP1 module error identification
Added module: AP1 PLCC32 ZIF NOR-1a
Added module: AP1 QFN24-1.02 ZIF MSP430-1
Added module: AP1 SOIC32 ZIF 445mil
Cypress CY7C53120E2 [SOIC32], CY7C53120E4 [SOIC32], added support
Echelon FT3120-E4 [SOIC32], added support
Renesas R5F10xx [SSOP20], added support
